Home › Forums › Products › Rackmount › ONE MORE BETA BUILD! V3.5B3 posted › Reply To: ONE MORE BETA BUILD! V3.5B3 posted
#127865
 Rozzer
this is completely different from what you described so far.
Now you are saying that you have patched FOLLOWER to the MODBLOCK LFO rate.
Before you said you patched the MODBLOCK LFO to Chorus delays 1 and 2.
FYI info, the PROG setting means that any patch *between MODBLOCK modulators AND presets parameters* will be valid for a single program. Here you describe patching a *MODBLOCK modulator (Follower) to another MODBLOCK modulator (LFO rate)*  and this is not covered by the PROG setting in the system.
It's obvious that if you patch a Modblock modulator to another, this will always work like that, regardless of the MODBLOCK preference (Global vs. Prog).
No bug to me.
thanks
I
