Home › Forums › Products › Rackmount › When using firewire does audio go through thr Dac? › Reply To: When using firewire does audio go through thr Dac?
March 7, 2008 at 7:01 am
#128161
Correct! In this case Logic and the Eventide are mutually transferring digital audio data. Anytime you use FireWire there is only a digital audio stream thru it.
best regards
i
