Home Forums Products Rackmount Recommended Cables for ADAT Reply To: Recommended Cables for ADAT
#128413
 Alexis
the only limitation we are aware of is the space between the ADAT I/O connections. Being a bit tight, you may want to look for cable that have a small connector vs. those with a big plastic/rubber mass. I have one here that works perfectly but unfortunately has no brand/model on it.
best
