Home › Forums › Products › Rackmount › Unnecessary AD/DA conversions › Reply To: Unnecessary AD/DA conversions
April 15, 2008 at 7:36 am
#128493
Well…. this depends on how you setup your pro tols session and rig. We can't possibly support this.
If your intention is to use the H8000 analog in to convert an analog signal to digital, then transfer it to ProTools via the H8000 ADAT outputs, this can be done with the correct routing. Outside the H8000 things depend on how you set your other gear.
best
I
