Home › Forums › Products › Rackmount › Bypass › Reply To: Bypass
#128549
Skerikmusic
    H Italo,
    In my configuration. RELAY BYPASS does not pass any audio when activated. Neither does MUTE ALL, only DSP BYPASS passes dry audio. Is it correct that RELAY BYPASS only works when using balanced XLR outputs? I am using unbalanced 1/4" cables, stereo analog outputs.
    Help???
    Thanks, Skerik…..
    Also, where can I learn about "LOW, MED, HIGH" in Externals, there is no mention of them in my manual. What do they do, etc????
