Home Forums Products Rackmount H8000 Reply To: H8000
#128625
the unit has 2 DSPs. It's very important you decide how you want to route them in your stereo setup:
SERIES
A>B
you then use 2 inputs and 2 outputs to connect to the rig.
Anything loaded in A will also be processed by B.
PARALLEL
A//B
you can use 2 inputs and 2 outputs and configure routing internally, in the H8000.
or you can use 4 I/Os, assigning 2 to DSP A and the other 2 to DSP B. This is a more versatile setup but requires an external mixer/router to properly manage 4 channels in a stereo setup.
best
