Home Forums Products Rackmount H3000 H7600 H8000 How many separate effects parameters can be controlled with a midi expression pedal continuously ? Reply To: H3000 H7600 H8000 How many separate effects parameters can be controlled with a midi expression pedal continuously ?
#128714
J20056
    I assume you don't care about rotary encoders and other synth controllers. Furthermore, I also assume you won't be stomping on the stomp buttons 5x per song, which would alleviate the risk that the stomp buttons are of lower quality, although I find the metal case to be of solid and rigid build quality. I have used my first unit for 4 years, and the second for 3 years and never had a problem. So as long as you mostly use it for switching programs and using the expression pedals, which you'll have 2 of, it sounds like a viable alternative.
    Let us know if you have very specific issues to solve, but otherwise, it should be just fine.
