Home › Forums › Products › Rackmount › Eclipse V3.5 Block bypass externals – problems › Reply To: Eclipse V3.5 Block bypass externals – problems
June 16, 2008 at 9:58 am
#128737
I am currently not using Eclipse Sys bypass but the loop bypass on my Pod Proxt. I gave up on the Eclipse bypass due to level problems. I have to say I am disappointed with Eventide on the issue over CC values. I use my Ground Control with a Pod Pro / Lexicon PCM 80 / TCD2 and Eventide is the only brand I use that has compatibility issues with the Ground Control. The Ground Control is very popular controller unit at a great price.
