Home › Forums › Products › Rackmount › Eclipse V3.5 Block bypass externals – problems › Reply To: Eclipse V3.5 Block bypass externals – problems
#128739
I just hooked up the Ground Control to my Mac & ran a MIDI monitor application.
Heres the "on" to the Eclipse:
20:30:14.243 From MIDI Port Control 2 Sustenuto Pedal 127
Heres the "Off"
20:30:56.726 From MIDI Port Control 2 Sustenuto Pedal 0
For the Pod for example it is sending:
For on:
20:31:41.068 From MIDI Port Control 1 Controller 25 127
For off:
20:32:17.174 From MIDI Port Control 1 Controller 25 0
So, to be clear you are saying the 127 should be 65 & the 0 64 (for off) ?
thanks
