Home › Forums › Products › Rackmount › Eclipse V3.5 Block bypass externals – problems › Reply To: Eclipse V3.5 Block bypass externals – problems
Hi, ok the Eclipse is connected directly to the Ground Control. Eclipse on Ch2, MIDI thru to POD xt (off) Note Phantom power running down MIDI cable from Eclipse to Ground Control.
Following is a MIDI stream selecting patch 33 Diamond Rain on my Eclipse:
22:08:09.584 From MIDI Port Program 1 1 POD PROGRAM
22:08:09.584 From MIDI Port Program 2 33 ECLIPSE PROG
22:08:09.585 From MIDI Port Program 3 0 NA
22:08:09.586 From MIDI Port Program 4 16 NA
22:08:09.586 From MIDI Port Program 5 1 NA
22:08:09.587 From MIDI Port Control 1 50 0 PODxt Mod BYPASS
22:08:09.588 From MIDI Port Control 2 65 127 Eclipse Block A ACTIVE
22:08:09.589 From MIDI Port Control 1 107 0 POD Loop BYPASS
22:08:09.590 From MIDI Port Control 2 66 127 Eclipse Block B ACTIVE
22:08:09.591 From MIDI Port Control 1 26 0 POD Comp BYPASS
22:08:09.592 From MIDI Port Control 1 25 0 POD DRIVE BYPASS
22:08:09.594 From MIDI Port Control 1 28 0 POD DELAY BYPASS
Heres another:
22:12:16.664 From MIDI Port Program 1 36
22:12:16.665 From MIDI Port Program 2 26
22:12:16.666 From MIDI Port Program 3 20
22:12:16.667 From MIDI Port Program 5 1
22:12:16.668 From MIDI Port Control 1 50 127 MOD ACTIVE
22:12:16.669 From MIDI Port Control 2 65 127 ECLIPSE BLOCK A ACTIVE
22:12:16.670 From MIDI Port Control 1 107 127 POD LOOP ACTIVE
22:12:16.671 From MIDI Port Control 2 66 127 ECLIPSE BLOCK B ACTIVE
22:12:16.672 From MIDI Port Control 1 26 0 COMP BYPASS
22:12:16.673 From MIDI Port Control 1 25 127 DRIVE ACTIVE
22:12:16.674 From MIDI Port Control 1 28 127 DELAY ACTIVE
cheers
