Reply To: Eclipse V3.5 Block bypass externals – problems
Home Forums Products Rackmount Eclipse V3.5 Block bypass externals – problems Reply To: Eclipse V3.5 Block bypass externals – problems
#128747
Mr_Clean
New program from the Ground Control, sending to Eclipse on chan 2 Prog 1 Reson Echos. 2 Blocks. GC sending Block A & B engaged CC 65 – 127, 66 – 127. Eclipse does not engage A & B. It engages both blocks in bypass despite the Ground C showing active. Sending only 1 program to Eclipse only, all other midi sends disengaged.
Then selected another program Echo Space of God both blocks engaged, Eclipse FXA on FXB off despite Ground Control showing Engaged. cheers
