Home › Forums › Products › Rackmount › Eclipse V3.5 Block bypass externals – problems › Reply To: Eclipse V3.5 Block bypass externals – problems
June 16, 2008 at 10:57 pm
#128757
It's a little difficult to know what to do here.
On one side, this is the way that Eclipse has always worked, so changing it may cause problems for people.
This would also be a surprisingly major change, so might cause other problems.
On the other side, the way it currently works is probably not for the best.
Requires some thought.
