Reply To: ECLIPSE in a guitar rig (amps wo FX loops)
Home Forums Products Rackmount ECLIPSE in a guitar rig (amps wo FX loops) Reply To: ECLIPSE in a guitar rig (amps wo FX loops)
#128847
John01W
Ok, here is what you do, go to suhr guitars and order a line out box(really great priced)….
http://www.suhrguitars.com/tonetools.aspx#lineOut
It's a lil' box that you put between your amp and speaker cab that will give you a line level signal of the sound after the amp and it's 100% safe and sounds killer. Take that line out from and run it into the Eclipse….Run the output of the Eclipse into a solid state power amp and run a wet/dry or wet/dry/wet setup. All those items cheap, and there's no way to better keep your sound intact.
