Home › Forums › Products › Rackmount › ECLIPSE in a guitar rig (amps wo FX loops) › Reply To: ECLIPSE in a guitar rig (amps wo FX loops)
September 7, 2008 at 6:00 am
#128996
….and if you add an effect series loop in your vox, use the suhr minimix (line mixer) and set your effects at 100% wet (same like wet/dry system) like this you'll keep the tone of the distortion. Just add an isptechnologies pedal if your using a Boost/Overdrive pedal and your in business!
Can go to the knowledgebase* but obviously a part is missing at the end (about using a line mixer).
*: http://www.eventide.com/AudioDivision/Support/Knowledgebase.aspx
