Home Forums Products Rackmount H8000 V5.3 now posted Reply To: H8000 V5.3 now posted
#129036
lbartram
    Hi: First, thanks for posting this update.
    I'm having the same symptoms as Sonic Nomad on my H8000FW. I downloaded the file to my Mac, and it came up with six files. Their exact names are as follows:
    o8.bam
    autoexec.bat
    FWTERM.BIM
    H8000.bin
    cmds.txt
    LOADBAM.exe
    Interestingly, the FWTERM.BIM file isn't a .BIN file, but maybe that's supposed to be that way. I copied these files, using my Mac, to the PC Card I used to install the last system update, and then ran the installer with the "2" key down at power up.
    Thanks to your instructions above, I know how to check to see if Revision: 5.3 was correctly installed. It was, but the SDD Version is wrong; it is the old one, 2 point
    My installer didn't finish gracefully from the card. At the end, I was just left with instructions on the screen of the H8000FW . I see a message flash that says "Success", that disappears quickly, then I am stuck looking at a screen that says "FWterm V1.2" The only options, each of which does nothing at all, is "restart" on the leftmost soft button and "done" on the rightmost button. I sat here looking at this for some time, thinking something would happen, but nothing did, so I powered off and back on, and this is where it sits. I've done this three times now.
    What should I do?
    Thanks.
