Home Forums Products Rackmount adat + firewire Reply To: adat + firewire
#129096
     Basically you have to understand the H8000's routing and memorize the User Manual. You could also try the Routing utility available from the Web Site, which will give you the schematics you request.
     Or, load factory routing "14 FireWire A-B". Then go to SETUP and hit the "outputs" key until you see "ADAT Outputs" in the top right. Turn the wheel until you see "FWIRE2 in 1" etc. This will connect the FireWire 2 input to the ADAT outputs. Similarly, connect ADAT inputs to the "FireWire2 outputs".
    Actually using this with a DAW is, however, beyond the scope of this forum.
