Home Forums Products Rackmount loop 20 ??????? help ! Reply To: loop 20 ??????? help !
#129108
simeon
    just thinking off the top of my head here…
    if you used DualLoop10 and tied an expression pedal to the input level of both loops and another expression pedal to the output level of both loops inversely, you could use the first pedal to control the input to the loops and the other to crossfade between them
    if you used a drum machine to send midi clock to the eclipse and set the t_loop parameter to 4 bars, then you could record a 4 bar phrase into one side… and then rocking the pedal would then fade out that loop and bring up the other, which you could then record a different 4 bars into. the first pedal would control the input to the loops, allowing you to jam over them, or add more material
    i guess it could be done, but there are easier ways to achieve this goal, i guess!
    sim
