Home › Forums › Products › Rackmount › Questions about eclipse update › Reply To: Questions about eclipse update
#129167
     You are correct to be concerned – it should disappear almost immediately.
    The problem is probably the card you are using. Make sure it is less than 4G and is formatted as FAT, not FAT32.
    A new card of less than 1G will probably be FAT. On a PC, you can specify the format type when formatting.
