Home › Forums › Products › Rackmount › H8000FW in a live guitar rig › Reply To: H8000FW in a live guitar rig
Hi Teddy
since I do not use MIDI pedalboards as they are all too limited for my needs, I have no specific model to advice. You need to look for any model that allows 10 of its footswitches to send out the same MIDI Continuous Controller #, each one with a different value.
Simply this, if the choice is CC #1:
Fsw #1 sends MIDI CC # 1 with value 1 > recalls Tweak 1
Fsw #2 sends MIDI CC # 1 with value 2 > recalls Tweak 2
Fsw #3 sends MIDI CC # 1 with value 3 > recalls Tweak 3
Fsw #4 sends MIDI CC # 1 with value 4 > recalls Tweak 4
Fsw #5 sends MIDI CC # 1 with value 5 > recalls Tweak 5
Fsw #6 sends MIDI CC # 1 with value 6 > recalls Tweak 6
Fsw #7 sends MIDI CC # 1 with value 7 > recalls Tweak 7
Fsw #8 sends MIDI CC # 1 with value 8 > recalls Tweak 8
Fsw #9 sends MIDI CC # 1 with value 9 > recalls Tweak 9
Fsw #10 sends MIDI CC # 1 with value 10 > recalls Tweak 10
I'm sure there are pedalboards out there that can do this; very likely they belong to mid_high or high range products, though, but still worth as they will allow greater flexibility and growth in the MIDI area in your future.
Hopefully other folks using MIDI pedalboards can add specific suggestions on the topic.
You may want to start checking companies websites to check their models' user manuals for the right info on this.
all the best
I
Show More...Show Less...
