Home › Forums › Products › Rackmount › Input LEDs › Reply To: Input LEDs
June 5, 2009 at 4:12 pm
#129791
The XTC send level is controlled by the volume on the front panel, this explains why you have little to no signal – try cranking the amp! The other way to do it is to run the amp in series and use the Master volume on the back as the overall master volume – the VOL controls on the front are now SEND level controls.
