Home › Forums › Products › Rackmount › shifting formants › Reply To: shifting formants
        June 5, 2009 at 5:50 pm
        #129796
UltraShifter is mostly a voice dedicated shifter. It allows both automatic calculation of correct formants in relation to pitch shifting and manual adjustments too.
If you are trying to venture to more uncharted directions it may not be the proper tool for you. I can only advice you test the unit and check if it's useful to your needs.
kind regards
I
