Home › Forums › Products › Rackmount › Bypass cuts sound volume….? › Reply To: Bypass cuts sound volume….?
July 25, 2009 at 9:38 am
#129949
i´m experiencing the same problem,with an important loss of volume when changing from bypass mode to fx mode.i´ve reduced my equipment to a minimum:just a synth going into the eventide thru analog inputs,and the analog outputs of the eclipse into a mixer.it seems that switching on effects wich use levels between wet and dry (such as delays,reverbs and so on ) drops the volume of the outcoming signal….
¿any explanation?thanks a lot in advance
hugo
