Home Forums Products Rackmount Internal checksum error V4 eclipse Reply To: Internal checksum error V4 eclipse
#129966
    I suspect there is a bug here, so suggest that people backup their user presets to a card before upgrading (always a good idea). Apologies to those for whom this advice comes too late.
    We upgraded the checksum tests in 3.5, so these errors are probably real. The battery becomes suspect if you perform a Setup/Utility/FIX and then power down overnight. If the error is back in the morning, this would point to a bad battery (easy enough to change).
    The battery should last many years, so if you have to change it too often, this would point to a hardware issue that is draining the battery.
