Home › Forums › Products › Rackmount › Internal checksum error V4 eclipse › Reply To: Internal checksum error V4 eclipse
#130003
Replacing the battery with the unit not powered on will most likely result with the loss of your
user-saved presets; thus you should back any user presets you don't want to loose. It is possible to change the battery while the unit is powered on and connected to mains, and this procedure would prevent the loss of user-saved presets. I however don't advise this, but some people do actually do this.
