Home Forums Products Rackmount H8000FW questions Reply To: H8000FW questions
#130036
Keep in mind that VSIG inputs and outputs are DSP I/Os, NOT the actual physical I/Os of the H8000.
The ROUTING function of the H8000 is what you need to program to connect physical I/Os to those DSPs I/Os.
Your example:
if your preset is mono audio, there is really no need to use in/out 2 in Vsig. Infact your amp SEND is mono and is sufficient to use a singe input. If your preset is stereo I/O then you coud have INPUT 1 of the H8000 routed to DSP inputs 1 and 2 and its outputs conncted to OUTPUT 1 for mono use, as this will be connected to your amp fx loop return.
If you are creating mono algorithms in Vsig, just use 1 I/O on the H8000. You won't need the others.
If you want to se factory stereo presets, you can connect INPUT 1 of the unit to both in1 and 2 of the DSP and then sum DSP outs 1 and 2 to H8000 OUTPUT 2.
Things depend on how you connect DSP I/Os to the H8000 I/Os.
I
