Home Forums Products Rackmount Brand New Unit! Advice on Routing p-p-please Reply To: Brand New Unit! Advice on Routing p-p-please
#130086
    Easy enough. Follow these steps:
    1) [SETUP] [inputs].
    2) turn wheel to right until you see "FWIRE in 1"
    3) down arrow
    4) turn wheel to right until you see "FWIRE in 2"
    The main inputs 1&2 are now set up for FWIRE 1/2. So now, lets connect these to the outputs 1&2:
    5) [outputs]
    6) down arrow once to select (highlight) the first two outputs
    7) turn wheel to left until you see "FWIRE in 1" & 2.  These are the inputs you selected above.
    Job done.
