Home Forums Products Rackmount H8000FW questions Reply To: H8000FW questions
#130197
Patill
    s/pdif 3 -> IN1
    -> IN5
    s/pdif 4 -> IN2
    -> IN6
    -> IN3
    -> IN7
    -> IN4
    -> IN8
    DSP A i/p routing
    s/pdif 3      -> IN1
      -> IN5
    s/pdif 4     -> IN2
      -> IN6
    -> IN3
      -> IN7
    -> IN4
       -> IN8
    DSP B i/p routing
    DSP A OUT 1 -> IN1
      -> IN5
    DSP A OUT 2 -> IN2
      -> IN6
     -> IN3
      -> IN7
    -> IN4
       -> IN8
    MAIN OUTPUTS (Analog)
      -> ANA1
    -> ANA2
      -> ANA3
    -> ANA4
    MAIN OUTPUTS (Digital)
    dsp B out 1 (+)
    -> DIG1
    dsp B out 2 (+)
    -> DIG2
    -> DIG3
      -> DIG4
    ADAT Outputs
    -> OUT1
    -> OUT5
    -> OUT2
    -> OUT6
    -> OUT3
    -> OUT7
    -> OUT4
    > OUT8
    AES Outputs
    MAIN OUT 5 -> OUT1
      -> OUT5
    MAIN OUT 6 -> OUT2
      -> OUT6
    -> OUT3
    > OUT7
    -> OUT4
    -> OUT8
    FIREWIRE1 Outputs
    -> OUT1
      -> OUT5
    -> OUT2
      -> OUT6
    -> OUT3
    > OUT7
    -> OUT4
    -> OUT8
    FIREWIRE2 Outputs
    -> OUT1
      -> OUT5
    -> OUT2
      -> OUT6
    -> OUT3
    > OUT7
    -> OUT4
    -> OUT8
    That´s it, it works like this and ONLY like this. If I put the S/PDIF 3 and 4 inputs on IN 3-8 and connect the following as it should work, nothing works.
    Also, I find it a little bit confusing, that when I use the Main Out (Analog), I have to choose MAIN OUT 1 and 2 at the AES Outputs, and when I choose Main Out (Digital) I have to use MAIN OUT 5 and 6 (as shown above) on the AES Outputs. I still don´t get it with the extra dots on the Main outputs in the routing program and why I have to choose output 5 and 6 when using digital out 1 and 2 instead of analog.
    I only get a delayed signal if I set the Main Out (Digital) 1 and 2 to S/PDIF 3 and 4 or when i set the AES Outputs 1 and 2 to S/PDIF.
    And guys, as I said, no offense, but the most people who choose this unit have a Mac ;).
