Home Forums Products Rackmount H8000FW questions Reply To: H8000FW questions
#130208
    Patill:
    lol ok, that may be possible :). I didn´t think about the presets inputs and outputs used, I thought they run over all the inputs and outputs of the DSPs but can only be used by 2 inputs and outputs at all, no matter where they are. I´ll check tomorrow immediately, this is a very good point.
    The DSP is in effect the preset (except for monolithic presets which use both), so the choice of inputs is an issue. Use 1 for mono, 1/2 for stereo, etc.
    Patill:
    Another quick question, when I have a 4 Pitch Shifters preset with "44" and I only hear two (or even only one) shifter(s), can I make the others "appear" by routing the Main Input 1 to all 4 DSP Inputs (1-4) and all the 4 DSP Outputs to Main Out 1? Since my Guitar is a mono instrument ;).
    Yes you can. And, for example, you could produce a stereo output by sending 1/2 to Main Out 1 and 3/4 to Main Out 2.
