Home › Forums › Products › Rackmount › Where’s my echo? › Reply To: Where’s my echo?
October 8, 2009 at 12:14 pm
#130327
The 2290 is mono in and "stereo out" in the sense that the dry+wet signal is sent to L/R output, and you can control the phase of the wet part of the signal…So, if your wet Left signal has + phase and Right signal has – phase, when you add together you have no signal…even if your wet signal is not at zero delay time…
