Reply To: Tap Tempo using latching footswitch connected to pedal 1 jack
Home Forums Products Rackmount Tap Tempo using latching footswitch connected to pedal 1 jack Reply To: Tap Tempo using latching footswitch connected to pedal 1 jack
#130370
Italo is right – a directly connected switch will give better tap results than MIDI.
A MIDI connection is always a little "rubbery", but will usually be OK if you have no alternative.
