Home › Forums › Products › Rackmount › Signal leakage › Reply To: Signal leakage
October 19, 2009 at 9:53 pm
#130410
preset #3910 has a signal leakage. In the Reverb tab, if I set the mod depth and mod rate to zero, then this signal doesn't disappear but at least, it is consistent. It's not the cables or some other fancy stuff. If I select a different preset, it's *ultra* quiet. It's a noise which is IN the algorithm.
Is there a way to remove this? It's driving me crazy because it's apparent with and without any signal present. Now that I am typing this, I can hear it from the other side of the room. 🙁
Regards,
Yannis
