Home Forums Products Rackmount H8000FW DSP B won’t output via analog Reply To: H8000FW DSP B won’t output via analog
#130594
    Running out of ideas ..
    You could try a CLEAR SETUP (press and hold SETUP on second startup screen).
    A few other questions:
    1) When you fed DSP A to 3&4 did they show on the output meters ?
    2) Have you tried this with many different presets ?
    3) Have you tried routing DSP B to AES/EBU 3&4 ?
