Home Forums Products Rackmount Volume and tone changes… Reply To: Volume and tone changes…
#130635
simeon
    just a note on bypass. your signal will always jump in level when you bypass the eclipse, because it's lower in mix level when you're not bypassed. the easiest way to solve this (imo) is not to bypass the eclipse at all, but to select a "thru" algorithm instead, with the level of the block set to -3db. this will maintain your dry level. sim
