November 12, 2009 at 8:11 pm #106628
Leroy2112
MemberHi this is my first post. I just got the Eclipse and I'm loving it but… the volume drops when I take it out of bypass (FX on) and the tone gets dulled too. I noticed that if I run it at 96kHz it's fine but then I can't use some of my favorite patches!!! Anyone know if there's a way to get my tone back at 48 kHz?
November 12, 2009 at 8:56 pm #119458
IDeangelis
MemberHI Leroy
let's get details….
-how the unit is connected ? (audio source/type of cables)
-what OS version is running on ?
I
November 12, 2009 at 10:00 pm #119459
Leroy2112
MemberI'm running a Strat > 1/4" cables > pedalboard > Eclipse 1/4" input A > Eclipse 1/4" output A > Fender 65 Deluxe Reverb input 1 with a clean tone. I'm running OS 4.0. I've got my Levels set to In Gain 7.0dB, Out Gain -20dB, Wet/Dry Mix 50%, Analog Level 0.0dB, I/O Mode Mono 1, Master Out 0.0dB. Meter setup is, Source – Analog In.
November 13, 2009 at 9:51 am #130586
IDeangelis
MemberTry setting Bypass mode to "DSP Bypass", under SETUP, MODES.
best
I
November 13, 2009 at 6:45 pm #130589
Leroy2112
MemberIt is…
November 14, 2009 at 6:53 pm #130605
Leroy2112
MemberSo any ideas of how to get my tone and volume the same when the Eclipse is on or bypassed?
November 16, 2009 at 1:24 am #130608
Leroy2112
MemberAlso… I've been trying to get my Eclipse to receive midi program changes via a midi foot switch to change patches but it works about 5% of the time. I hooked up a Alesis MidiVerb 4 and tried it and it works perfectly! Man I really need this Eclipse to change patches in a live situation via my midi foot swicth. Please advise. I've used short cables tweeked all the midi settings but nothing makes the Eclipse behave the way I need it…
November 16, 2009 at 9:33 am #130611
IDeangelis
MemberLeroy
regarding BYPASS:
Relay Byp
When this is selected, the analog XLR inputs and outputs are connected by a relay (you can hear it click when you operate the switch). The digital inputs and outputs are connected electronically, as in DSP bypass.
The ¼” jacks will be muted, so you should not use relay bypass if you are using these jacks.
Note that when Eclipse is powered down, the same relay connects the analog XLRs, so that signal can pass through.DSP Byp (DSP bypass – the normal mode)
When this is selected, both effects blocks are electronically bypassed, preserving all global levels. This means, for example, that if you were coming in digital and going out analog, you would still have signal when bypassed, in contrast to relay bypass above.If you are having tone/level problems with DSP Bypass, it may depend on one or more of several factors:
-input/output levels settings
-eccessive cables length/poor quality. Eclipse and long guitar cords don't match. Studio grade cables are recommended.
-levels/impedance mismatching of gear connected to Eclipse. 1/4" jacks should ONLY be used for instrument level signals (-20dB/-10dB). You don't specify what kind of signal comes out of your pedalboard.
In general, Eclipse best connection place is an FX loop, using XLRs connectors. If you can, try that. Also, try taking the pedalboard away anc connect Eclipse to your gtr. Is the problem still there? That may be an incompatibility between the two. We have seen this in the past. Some pickups require hefty buffers to directly deal with fx processors.
best
Show More...Show Less...I
November 17, 2009 at 5:08 pm #130631
Leroy2112
MemberPlease advise…
November 17, 2009 at 5:48 pm #130632
IDeangelis
MemberLeroy
Eclipse uses MIDI Maps to organiza the way Program Changes address the hundreds of presets available in the unit. You don't mention any detail about your presets, MIDI settings, etc.
The best advice at the moment is to check the user manual where MIDI maps are very well explained.
best
I
November 17, 2009 at 6:41 pm #130633
Leroy2112
MemberThe midi map is not the issue it will go to the right patch after I select it on my midi controller but only about 5% of the time. It's just not switching consistently. All my other midi gear is switching fine.
November 17, 2009 at 6:48 pm #130634
IDeangelis
MemberLeroy
without details we can't help you.
Please provide the following:
-where are stored the presets you intend to recall via MIDI? On which numbers?
-Which MIDI Map are you using?
-MIDI settings of Eclipse (channel)?
-describe the MIDI chain between the units
-how your MIDI controller is set to address Eclipse via MIDI?
best
I
Show More...Show Less... -
November 17, 2009 at 7:03 pm #130635
simeon
Participantjust a note on bypass. your signal will always jump in level when you bypass the eclipse, because it's lower in mix level when you're not bypassed. the easiest way to solve this (imo) is not to bypass the eclipse at all, but to select a "thru" algorithm instead, with the level of the block set to -3db. this will maintain your dry level. sim
November 17, 2009 at 9:55 pm #130636
Leroy2112
Member1. Patch #"s 500 – 504 on the card
2. Midi map 3
3. The Eclipse is receiving midi on midi channel 1
4. Right now it's hooked up directly to the midi controller
5. I'm send out midi program change messages via my midi foot switch
November 17, 2009 at 11:09 pm #130637
IDeangelis
Member#1/2/3/4 are ok
in #5 you should make sure that nothing is sent out on OMNI. Every unit in the rig should use a separate MIDI Channel. Don't use OMNI on any unit.
Everything looks ok to me so I can only think there is something wrong in what comes out of the pedalboard or you may need to execute a CLEAR SETUP on the Eclipse. Check the latest manual pages for that.
I also suggest you update Eclipse to 4.01 which fixes some other things.
best
I
November 18, 2009 at 3:27 am #130639
Leroy2112
MemberI just got it to work! I don't know what the problem was but it's working now!!!! Now I need to update to 4.1.
Thanks for all you help!!!!
November 18, 2009 at 8:29 am #130641
IDeangelis
MemberMay be one or more of the following:
-cosmic rays
-2012 approaching fast!
-magic
-spells!
cheers
I
