Home Forums Products Rackmount Delay patches on dsp 4000 Reply To: Delay patches on dsp 4000
#130665
Italo
I adjusted the wet/dry balance for the delay effects, it's working good now…thanks for the tip. The delays and reverbs contained in the dsp 4000 sound huge…
As for the circular delay sound, I wanted to thank you for sending me the file, it is now on my dsp 4000. This preset in its current configuration is well made (especially the diffusion parameter that's included) but I wanted to tell you a little bit more about the PCM 70 circular delay settings as I could find some decent and pretty accurate information on them. Here's the link: http://www.hugeracksinc.com/forum/viewtopic.php?t=45310&sid=68438cc5f95fd93cf95670e1b9a1c7f3
From this link it seems that the circular delay is actually a 3 tap delay and not a 3 delay patch. Here are some clips of the Lexicon PCM 70 circular delay sound: http://www.rooockstar.com/rooockers/Pala/416/effects/PCM_70
So my question is this: is it possible to modify the preset you sent me or create one from scratch that would include 3 taps instead of 3 delays (tap 1, tap 2, tap 3)? The rest of the preset parameters could work to me since it has feedback, level and diffusion controls…
Thanks again
Have a nice weekend too
Sylvain
