Home › Forums › Products › Rackmount › H8000FW Ableton routing › Reply To: H8000FW Ableton routing
January 13, 2010 at 1:06 am
#130920
nickrose:
MicrokevH8000:
don't know how to check if I've got the latest H8000 software.
It will show the version at the second startup screen. Should be V5.3
Yup. I'm running 5.3
Quote:
MicrokevH8000:
but I don't exactly understand how to separate the routing to DSP B and DSP A
First step is to see if one of the factory routings suits your purposes. Look at the diagrams in the User Manual and see which is closest to what you want.
Show More...I think the one I'm running is probably the best at the moment. Firewire 8 track AB. Am I correct in thinking that to route audio from the computer to DSP B, I should select channels 5-8 from my workstation, and then set DSP B to 'THRU' ?
