Home › Forums › Products › Rackmount › Wet/Dry Midi CC › Reply To: Wet/Dry Midi CC
January 18, 2010 at 11:03 pm
#130956
Thanks for all your help today. Was able to set up a preset on my midi controller solely dedicated to a wet/dry feed by way of a pedal. This way when scrolling through and learning algorithms, I can easily find the best mix for that preset: hands-off. Then when saving it and calling it up w/ a program change, I can add the pedal controller, and viola! It's ready to be mixed.Ohh! Just had a thought. I could ball-park what I think would be the best starting point with the wet/dry mix with its own CC, then use the pedal to adjust as needed just in case it doesn't work in one venue vs. another. Whoopee!
Can't thank you enough!
