Home Forums Products Rackmount Routing Nightmare help Reply To: Routing Nightmare help
#131037
    Normal ADAT is limited to 48kHz (the restriction is the bandwidth of the optical system).
    H8000FW also supports S-MUX, which will give you 4 channels at 88/96K. But, not many other things support this, and it has not been heavily tested.
    If the unit shows slipping, this will be because you have not selected ADAT as the sync source (the routing presets do NOT include sync source selection). Small slipping is usually un -noticeable (masked by source material), but big slipping causes objectionable clicks and other artefacts.
