Home › Forums › Products › Rackmount › Midi and Ground Control Pro › Reply To: Midi and Ground Control Pro
February 20, 2010 at 3:46 pm
#131205
I set the ground control on channel 1 and the Eclipse to Omni. I didn't realize I had to set a midi map. Does the default work?
I didn't try the cable in the out, but I did try to use the ground control for my Podxt live and it didn't seem to do anything with it either. I wiped the memory of the ground control and that didn't help either. Thanks for the help.
