Home Forums Products Rackmount UltraShifter Autocorrect tweaks? Reply To: UltraShifter Autocorrect tweaks?
#131269
    Hi Phil – I was leaving this one for Italo. But, from the Ultrashifter documentation:
    hysteresis: Controls how much the pitch may move outside the range of the current
    note before the current note is changed to reflect that pitch.
    Hysteresis can prevent
    the oscillating between adjacent notes that can occur when the pitch is in
    between two notes. Notes are typically 100 to 200 cents apart so 50 cents of
    hysteresis would allow
    the pitch to wander a lot before a higher or lower note was
    recognized.
    range: Controls the smallest error in pitch that will be corrected – if the
    pitch deviates from a true note by less than this amount, no correction will be
    made. This value may be used to let vibrato through or to enable correction only
    on notes that are badly out of tune
