Reply To: Weird Flangin background noise
Home Forums Products Rackmount Weird Flangin background noise Reply To: Weird Flangin background noise
#131287
IDeangelis
Jan
one thing that may not be clear to most users is this:
-if Eclipse system dry/wet balance (under LEVELS) is set to 100% FULL WET, dry sound can be still passed thru and hearable IF the used preset FXA MIX or FXB MIX (if the presets uses two algorithms) is not set to 100% wet. In other words full wet is true only if system AND presets dry/wet mixes are set to 100% wet.
With a parallel fx loop this may happen very easily as the analog dry signal and any digital dry signal copy may overlap causing phase canceling issues.
all the best
I
