Home › Forums › Products › Rackmount › H8000 heat and cooling › Reply To: H8000 heat and cooling
March 15, 2010 at 6:54 pm
#131326
A free space on top and below is perfectly adequate to dissipate heat. That's actually the best scenario as airflow from below rise, takes the heat and continue rising as heat tends to go up.
The display generates heat itself as there are high voltage parts in its components. It only needs adjusting contrast after a few hours of duty. You can't really do much else. It's perfectly fine.
all the best
I
