Home › Forums › Products › Rackmount › Trouble Upgrading. › Reply To: Trouble Upgrading.
#131364
So, very likely the card or the adapter don't work well with updates. You should try another card. There are several threads on this topic in the forum.
Regarding the self-test, just power the unit off; read any reports from the tests before.
Use cards below 2 GB. This update enables higher capacity cards to be used, when installed.
all the best
I
