Home Forums Products Rackmount Will Pay for custom H8000 patches Reply To: Will Pay for custom H8000 patches
#131388
Hi Jeff
it's already in the 5.5beta OS, available on the website.
The new OS also features TF and MF pedals presets and some new presets:
-BANK 6-
BULGE TALES
4 chorusdelays feed a 2 voice
modulatable shifter. Balance controls the final mix between the 2 fx. Tweaked for classic M.L. chorusdelays.
Stereo I/O
-BANK 8-
CHORS'N'ECHO
4 chorusdelays set as classic '80s racks sounds.
Stereo I/O
-BANK 15-
AUTOPITCHCORRECT 4CH
Automatically corrects any vocal that is within half a semitone of the correct pitch.  Outside of this range it will pull to the next note. Note that this process will quantize the pitch of the signal (you do have control over the quantize factor) so becareful, as you may loose slides and 4 independent mono channels I/O.
-BANK 16-
FoH FX RACK #1
In1>dtune+dly&verb in parallel>out1&2
in2>dly+verb in parallel>out&2
in3>detune
in4>detune
both detuners 3&4 have dly+verb in parallel>out3&4
FoH FX RACK #2
In1>dtune>dly+diff/verb in parallel>out1&2
in2>detune
in3>detune
in4>detune
all+dly/verb in parallel>out3&4
-BANK 17-
GILMOUR DLYS & PAN
Gilmour style stereo delays with frequency shifter panning the image.
Stereo I/O.
-BANK 65-
2 TC2290s
2 TC2290 Dynamic Delays in parallel.
Delay can be tapped in w/an ext switch.
Set it in the system menu.
Delay modulation and level can be dynamically controlled. Dly and Dry panning can be dynamically controlled too. Dly/dyn/pan mod switches enable dynamics controlled modulations.
Tweaked for dyn
panning/ducking/detuning echo.
In 1+2 > first 2290 > out 1+2
In 3+4> second 2290 > out 3+4
Dual summed in/stereo out.
CIRCULAR DELAYS
Pcm70 V2.0 very popular preset now available on your Eventide.
Stereo I/O.
DEP5_alg6
Roland DEP5 algorithm 6 replica.
EQ>Reverb>Chorus in series and
parallel.
16 bit dithering applied.
Sum mono in/ stereo out.
PAN DELAYS
Stereo I/O.
give it a try!
cheers
I
