Home › Forums › Products › Rackmount › Problems with ENVELOPE module › Reply To: Problems with ENVELOPE module
April 26, 2010 at 9:53 am
#131575
Thomas
when an algorithm is loaded in Vsig, the module(s) version(s) is determined by the database used by Vsig. So if you are currently using an H8000 databse and load a DSP4000 preset, Vsig is using an H8000 envelope module, NOT the 4000's.
So, in order to make things right:
-make sure you have a 4000 database in Vsig when editing an algorithm for the 4000.
-the same is tru for the H8000
-save presets as .sig, not .sif. We changed some years ago and there may be some incompatibilities with current Vsig version.
best
I
