Home › Forums › Products › Rackmount › Problems with ENVELOPE module › Reply To: Problems with ENVELOPE module
April 26, 2010 at 12:42 pm
#131578
Thomas
as I said, if you load the patch you sent me or even the example in the patch editor and change from sine to triangle and then immediately back to sine, it will work…provided you have a threshold of -30 dB or -40. Now the questions are:
-is it the way it works correct?
-the fact it doesn't work upon loading…is it a bug?
I
