Home › Forums › Products › Rackmount › Severe Update Problem to 4.01 on Compact Flash Card. Mangled the entire OS. › Reply To: Severe Update Problem to 4.01 on Compact Flash Card. Mangled the entire OS.
#131612
Good the problem is solved.
I said the Eclipse doesn't have a step modulator AND that it could be programmed on the Vsigfile Editor supported units, like the H7600 or H8000FW. You can't create algorithms on Eclipse.
The way it may be created can be different from other similar functions in other units, so things should be well evaluated before attempting to do it.
all the best
I
