Home › Forums › Products › Rackmount › some Q:s regarding eclipse! › Reply To: some Q:s regarding eclipse!
#131847
    If you just want to add MIDI CC control to a parameter, you can do this on the unit.
    The details vary with the unit (see User Manual) but essentially you select the parameter, press and hold a key, and then either enter the MIDI values or use the MIDI Capture feature.
