Home Forums Products Rackmount H8000fw Out 3 and 4 NON FUNCTIONNING Reply To: H8000fw Out 3 and 4 NON FUNCTIONNING
#131933
    Sounds like everything is working as expected – some presets are 2 in 4 out (these are probably what you are looking for), others are 4 in 4 out – these usually require 4 inputs, but can often be used 2 in 2 out.
    It all depends on knowing the presets and knowing what you are trying to do – there are well over 1000 presets, so you should have many options – for example, if you set Program/criteria to only list stereo in, quad out, it shows 191 presets at 48K.
