Home Forums Products Rackmount H800FW: “New OS detected, return to factory default ?” Reply To: H800FW: “New OS detected, return to factory default ?”
#131938
unguitar
    Dear Nick,
    I have downloaded and installed the latest 5.5 ( by the way, on my machine the pc to serial cable doesn't look to work as the .exe doesn't execute itself) through card.
    All the procedure went fine.
    At the end I answered "yes" to the "return to factory defaults" page, then switched it off, switch on again, loaded my setups and routings, switched off again.
    At this point, once again I got the message of the title.
    I answered "no" as I wanted to check if all was fine.
    Remote works fine now.
    I checked about a problem there was in all previous releases since 5.5: preset 2120. This is still screwed up.
    Is there a way I can check the actual Os release it's on the machine now.
    I see that all the confusion about releases' names can be a little tricky.
    Thanks,
    Luca
